이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the device upside down.
Remove all four rubber feet by prying them out using the metal spudger.
Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
Gently move the wire aside so that it is not in the way.
Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
Gently remove the black cover.
Underneath, you will see a clear plastic cover that should be removed as well.
Cut the zip tie that holds the black, blue, red, and yellow wires together.
다른 2명이 해당 안내서를 완성하였습니다.
