주요 콘텐츠로 건너뛰기
Cuisinart CPB-380 Motor Replacement
필요한 것
  1. Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: 1 단계, 이미지 1/3 Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: 1 단계, 이미지 2/3 Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: 1 단계, 이미지 3/3
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Cuisinart CPB-380 Motor Replacement: 2 단계, 이미지 1/2 Cuisinart CPB-380 Motor Replacement: 2 단계, 이미지 2/2
    • Remove the base from the body of the blender.
  3. Cuisinart CPB-380 Motor Replacement: 3 단계, 이미지 1/3 Cuisinart CPB-380 Motor Replacement: 3 단계, 이미지 2/3 Cuisinart CPB-380 Motor Replacement: 3 단계, 이미지 3/3
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  4. Cuisinart CPB-380 Motor Replacement: 4 단계, 이미지 1/3 Cuisinart CPB-380 Motor Replacement: 4 단계, 이미지 2/3 Cuisinart CPB-380 Motor Replacement: 4 단계, 이미지 3/3
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover.
    • Underneath, you will see a clear plastic cover that should be removed as well.
  5. Cuisinart CPB-380 Motor Replacement: 5 단계, 이미지 1/2 Cuisinart CPB-380 Motor Replacement: 5 단계, 이미지 2/2
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
  6. Cuisinart CPB-380 Motor Replacement, Motor: 6 단계, 이미지 1/2 Cuisinart CPB-380 Motor Replacement, Motor: 6 단계, 이미지 2/2
    • Remove the four 13mm screws holding down the frame located at the bottom of the inverted blender using the Phillips #2 screwdriver.
    • Remove frame.
  7. Cuisinart CPB-380 Motor Replacement: 7 단계, 이미지 1/2 Cuisinart CPB-380 Motor Replacement: 7 단계, 이미지 2/2
    • Grab the motor by the black gear and the white filter.
    • Unscrew the black gear.
  8. Cuisinart CPB-380 Motor Replacement: 8 단계, 이미지 1/3 Cuisinart CPB-380 Motor Replacement: 8 단계, 이미지 2/3 Cuisinart CPB-380 Motor Replacement: 8 단계, 이미지 3/3
    • With the metal spudger remove the four rubber stoppers.
    • Remove the four 13mm screws with the Phillips #2 screwdriver.
  9. Cuisinart CPB-380 Motor Replacement: 9 단계, 이미지 1/1
    • Separate the top from the motor.
    • Pinch perpendicular to the flat surface and pull out the blue wire.
결론
다른 2명이 해당 안내서를 완성하였습니다.
William Hesse
회원 가입일: 09/24/18
454 평판
안내서 2개 작성하였습니다
댓글 2개
What is the part number and price for Cuisinart CPB-380 Motor?
Paul Hagen - 답글
What is the part number and price for Cuisinart CBD-380 motor and price....
Paul Hagen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 8
30일 전: 49
전체 시간: 3,284
