부품
지정된 부품이 없습니다.
Turn the device upside down.
Remove all four rubber feet by prying them out using the metal spudger.
Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
Remove the four 13mm screws holding down the frame located at the bottom of the inverted blender using the Phillips #2 screwdriver.
Remove frame.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
