주요 콘텐츠로 건너뛰기
Cuisinart DCC-1100 Hot Plate Replacement
필요한 것
  1. Cuisinart DCC-1100 Hot Plate Replacement, Hot Plate: 1 단계, 이미지 1/1
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Hot Plate Replacement: 2 단계, 이미지 1/1
    • Remove the coffee pot and place the coffee maker upside down.
  3. Cuisinart DCC-1100 Hot Plate Replacement: 3 단계, 이미지 1/1
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
  4. Cuisinart DCC-1100 Hot Plate Replacement: 4 단계, 이미지 1/1
    • Remove the bottom panel.
  5. Cuisinart DCC-1100 Hot Plate Replacement: 5 단계, 이미지 1/1
    • Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
  6. Cuisinart DCC-1100 Hot Plate Replacement: 6 단계, 이미지 1/1
    • Remove the retaining bracket and allow it to hang off of the heating element.
  7. Cuisinart DCC-1100 Hot Plate Replacement: 7 단계, 이미지 1/1
    • Remove the hot plate from the heating element.
    • New thermal paste should be applied at time of installation.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Josh Harvey
회원 가입일: 01/25/18
889 평판
안내서 4개 작성하였습니다
USF Tampa, Team S20-G4, Passmore Spring 2018 USF Tampa, Team S20-G4, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G4
4 회원들
안내서 7개 작성하였습니다
댓글 13개
thank you for this informative display.
I have broken many expensive glass carafs for my cuisinart coffeemaker and finally purchased a cuisinart thermal caraf.
I do not need the hotplate to heat, so what do I do to stop the heating process?
I imagine I would need to remove one of the attached lines to the heating element, yes?
Thanks.
Luciano
luciano1213@msn.com
Luciano Muzzatti - 답글
Hi, Thanks for sharing this information. I have an older Krups coffee maker that still works great but the hot plate is warn. I cannot seem to find a replacement plate for any Krups coffee maker models. Any suggestions? Thanks!
Paulette Paglia - 답글
Josh
where do I buy the replacement hot plate?? I have the sis 15 coffeemaker and I have googled all over the place?? Thank u
linkev428 - 답글
Yes, where do you buy the part??
Kathy Johnston - 답글
Yes my question is where do you get the new hot plate? Any direction appreciated.
DougB - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 30
전체 시간: 6,167
