주요 콘텐츠로 건너뛰기
Cuisinart DCC-1100 Power Cord Replacement
필요한 것
  1. Cuisinart DCC-1100 Power Cord Replacement, Power Cord: 1 단계, 이미지 1/2 Cuisinart DCC-1100 Power Cord Replacement, Power Cord: 1 단계, 이미지 2/2
    • Unplug the maker, remove the coffee pot, and flip upside down.
  2. Cuisinart DCC-1100 Power Cord Replacement: 2 단계, 이미지 1/2 Cuisinart DCC-1100 Power Cord Replacement: 2 단계, 이미지 2/2
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
    • Remove the bottom panel.
  3. Cuisinart DCC-1100 Power Cord Replacement: 3 단계, 이미지 1/2 Cuisinart DCC-1100 Power Cord Replacement: 3 단계, 이미지 2/2
    • Push the power cord inward and away from the plastic protection plate.
  4. Cuisinart DCC-1100 Power Cord Replacement: 4 단계, 이미지 1/2 Cuisinart DCC-1100 Power Cord Replacement: 4 단계, 이미지 2/2
    • Remove the two 1.4mm Phillips #0 screws from the plastic protection plate.
    • Remove the plastic protection plate.
  5. Cuisinart DCC-1100 Power Cord Replacement: 5 단계, 이미지 1/3 Cuisinart DCC-1100 Power Cord Replacement: 5 단계, 이미지 2/3 Cuisinart DCC-1100 Power Cord Replacement: 5 단계, 이미지 3/3
    • Remove the two 1.6mm Phillips #1 screws from the heating element.
    • Using a flathead screwdriver to remove the outer clips holding the heating unit in place.
    • Flip the heating element up to allow access to the circuit board.
  6. Cuisinart DCC-1100 Power Cord Replacement: 6 단계, 이미지 1/2 Cuisinart DCC-1100 Power Cord Replacement: 6 단계, 이미지 2/2
    • Pull out the circuit board and rest it on the side of the machine.
    • Desolder the power cable from the motherboard.
결론
Nicholas Eales
회원 가입일: 01/25/18
272 평판
안내서 1개 작성함
USF Tampa, Team S20-G4, Passmore Spring 2018 USF Tampa, Team S20-G4, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 28
전체 시간: 1,962
