주요 콘텐츠로 건너뛰기
Cuisinart DCC-1100 Selection Knob Replacement
필요한 것
  1. Cuisinart DCC-1100 Selection Knob Replacement, Selection Knob: 1 단계, 이미지 1/2 Cuisinart DCC-1100 Selection Knob Replacement, Selection Knob: 1 단계, 이미지 2/2
    • Remove the coffee pot.
  2. Cuisinart DCC-1100 Selection Knob Replacement: 2 단계, 이미지 1/2 Cuisinart DCC-1100 Selection Knob Replacement: 2 단계, 이미지 2/2
    • Open the lid.
    • Remove the two 1.6mm Phillips #1 screws from the lid.
  3. Cuisinart DCC-1100 Selection Knob Replacement: 3 단계, 이미지 1/1
    • Remove the lid from the coffee maker.
  4. Cuisinart DCC-1100 Selection Knob Replacement: 4 단계, 이미지 1/1
    • Remove the two 1.3mm screws from the display.
  5. Cuisinart DCC-1100 Selection Knob Replacement: 5 단계, 이미지 1/2 Cuisinart DCC-1100 Selection Knob Replacement: 5 단계, 이미지 2/2
    • Push the display into the maker so that way you can access the screws in the back.
    • Remove the four 1mm Phillips #0 screws from the back.
  6. Cuisinart DCC-1100 Selection Knob Replacement: 6 단계, 이미지 1/2 Cuisinart DCC-1100 Selection Knob Replacement: 6 단계, 이미지 2/2
    • Remove the back panel.
    • Remove the front panel from the display.
  7. Cuisinart DCC-1100 Selection Knob Replacement: 7 단계, 이미지 1/1
    • Remove the three 1mm Phillips #0 screws from the knob.
  8. Cuisinart DCC-1100 Selection Knob Replacement: 8 단계, 이미지 1/1
    • Remove the knob from the front panel.
  9. Cuisinart DCC-1100 Selection Knob Replacement: 9 단계, 이미지 1/1
    • Remove the plastic ring from the knob.
결론
Josh Harvey
회원 가입일: 01/25/18
889 평판
안내서 4개 작성하였습니다
USF Tampa, Team S20-G4, Passmore Spring 2018 USF Tampa, Team S20-G4, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 898
