주요 콘텐츠로 건너뛰기
Cuisinart DCC-1200 Coffee Carafe Handle Replacement
필요한 것
  1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: 1 단계, 이미지 1/3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: 1 단계, 이미지 2/3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: 1 단계, 이미지 3/3
    • Wedge the metal spudger between the plug and the handle.
    • Carefully pry the plug with the metal spudger by applying pressure around the plug.
    • Too much pressure and prying can damage the plug.
  2. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 2 단계, 이미지 1/2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 2 단계, 이미지 2/2
    • Use the bit driver with the Phillips PH1 bit to remove the 27 millimeter long screw in the base of the handle.
  3. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 3 단계, 이미지 1/1
    • Lift up on and remove the lid from the carafe.
  4. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 4 단계, 이미지 1/2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 4 단계, 이미지 2/2
    • Position the metal spudger underneath the top cap of the handle.
    • Gently pry up to extract the upper assembly cap.
    • Pry carefully to prevent from causing aesthetic damage to upper assembly cap.
  5. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: 5 단계, 이미지 1/1
    • Use the bit driver with the Phillips PH1 to remove the 5 millimeter screw in upper assembly of handle.
    • Remove handle by lifting straight up.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Austin Wheaton
회원 가입일: 02/15/18
861 평판
안내서 4개 작성하였습니다
UW Stout, Team S8-G1, Ogden Spring 2018 UW Stout, Team S8-G1, Ogden Spring 2018 회원
UWSTOUT-OGDEN-S18S8G1
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I needed this guide after my spouse put the carafe in the dishwasher and the handle sloshed no matter how much I shook it. It turns out water is easily trapped under the top cap; even though there's a drain hole into the handle, it doesn't seem to want to drain. I've wiped it off and left it to dry completely before reassembling it.
Max - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 33
전체 시간: 3,730
