주요 콘텐츠로 건너뛰기
Cuisinart DCC-3200 Hot Plate Replacement
필요한 것
  1. Cuisinart DCC-3200 Hot Plate Replacement, Hot Plate: 1 단계, 이미지 1/1
    • Unplug the device and flip it over so the bottom is facing upwards.
    • Remove the four screws.
    • Remove the bottom panel.
  2. Cuisinart DCC-3200 Hot Plate Replacement: 2 단계, 이미지 1/1
    • Remove the two screws from the silver brace.
  3. Cuisinart DCC-3200 Hot Plate Replacement: 3 단계, 이미지 1/2 Cuisinart DCC-3200 Hot Plate Replacement: 3 단계, 이미지 2/2
    • Use a spudger to wedge the red tube off of the metal.
    • Repeat this for the other side of the silver pipe deeper in the device.
  4. Cuisinart DCC-3200 Hot Plate Replacement: 4 단계, 이미지 1/1
    • Pick up the middle pipe and slide the hot plate out of its area.
    • Apply new thermal paste to the hot plate.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hamad Khan
회원 가입일: 03/04/16
385 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 8-3, Botvin Spring 2016 UMass Dartmouth, Team 8-3, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G3
3 회원들
안내서 3개 작성하였습니다
댓글 5개
Where can one purchase the burner plate?
john Vet - 답글
Same question as John Vet
Bob Stimson - 답글
Did anyone ever get a response as to where a replacement could be purchased?
Joe Lubrant -
Did response provide required info?
Joe Lubrant - 답글
Same question: where can we purchase the burner plate?
Cresny - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 70
전체 시간: 4,981
