주요 콘텐츠로 건너뛰기
Cuisinart DFP-14BCN Bowl Replacement
  1. Cuisinart DFP-14BCN Bowl Replacement, Bowl: 1 단계, 이미지 1/3 Cuisinart DFP-14BCN Bowl Replacement, Bowl: 1 단계, 이미지 2/3 Cuisinart DFP-14BCN Bowl Replacement, Bowl: 1 단계, 이미지 3/3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Bowl Replacement: 2 단계, 이미지 1/1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Bowl Replacement: 3 단계, 이미지 1/3 Cuisinart DFP-14BCN Bowl Replacement: 3 단계, 이미지 2/3 Cuisinart DFP-14BCN Bowl Replacement: 3 단계, 이미지 3/3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Bowl Replacement: 4 단계, 이미지 1/1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Bowl Replacement: 5 단계, 이미지 1/3 Cuisinart DFP-14BCN Bowl Replacement: 5 단계, 이미지 2/3 Cuisinart DFP-14BCN Bowl Replacement: 5 단계, 이미지 3/3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maddie McCool
회원 가입일: 10/06/16
144 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-3, Livingston Fall 2016 Cal Poly, Team 10-3, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G3
3 회원들
안내서 7개 작성하였습니다
댓글 5개
All of what you say is pretty obvious, of course. My problem is that the bowl lid won’t lock onto the bowl, apparently because there’s a white plastic hook in the area of the locking mechanism. Not obvious what the purpose of that hook is, as it’s not mentioned in the manual or video. I could be wrong, but maybe that plastic hook is not supposed to be there? I’ve asked Cuisinart, and am awaiting a reply. I told them I resent having to dig for info on an appliance I’ve been using for decades. Poor design, or poor documentation, or both. Got any suggestions?
Ken - 답글
Hello Ken, I have the same problem with my DLC-7, (017-B) lid not locking. Did you find a solution?
f eguia -
Never mind. I found out the feeder goes in the back, not the front. Then it works.
Ken - 답글
I bought a new bowl for my Cuisinart when the old bowl cracked. The new bowl came and fits the machine nicely, but the old lid won’t lock onto the new bowl. Is there a fix for this or do I now have to buy two new lids for my new bowl?
Laura
laura_blunk - 답글
I tried to attach the lid with bowl inserted with handle in back. Now I can not separate the lid from the bowl. Lid comes apart on each place except for the clamp opposite the feeder. Help!!!!
maxine snider - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 44
전체 시간: 9,988
