주요 콘텐츠로 건너뛰기
Cuisinart DFP-14BCN Buttons Replacement
필요한 것
  1. Cuisinart DFP-14BCN Buttons Replacement, Bowl: 1 단계, 이미지 1/3 Cuisinart DFP-14BCN Buttons Replacement, Bowl: 1 단계, 이미지 2/3 Cuisinart DFP-14BCN Buttons Replacement, Bowl: 1 단계, 이미지 3/3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Buttons Replacement: 2 단계, 이미지 1/1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Buttons Replacement: 3 단계, 이미지 1/3 Cuisinart DFP-14BCN Buttons Replacement: 3 단계, 이미지 2/3 Cuisinart DFP-14BCN Buttons Replacement: 3 단계, 이미지 3/3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Buttons Replacement: 4 단계, 이미지 1/1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Buttons Replacement: 5 단계, 이미지 1/3 Cuisinart DFP-14BCN Buttons Replacement: 5 단계, 이미지 2/3 Cuisinart DFP-14BCN Buttons Replacement: 5 단계, 이미지 3/3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Buttons Replacement, Back Casing: 6 단계, 이미지 1/2 Cuisinart DFP-14BCN Buttons Replacement, Back Casing: 6 단계, 이미지 2/2
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Buttons Replacement: 7 단계, 이미지 1/2 Cuisinart DFP-14BCN Buttons Replacement: 7 단계, 이미지 2/2
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Buttons Replacement: 8 단계, 이미지 1/3 Cuisinart DFP-14BCN Buttons Replacement: 8 단계, 이미지 2/3 Cuisinart DFP-14BCN Buttons Replacement: 8 단계, 이미지 3/3
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Buttons Replacement: 9 단계, 이미지 1/2 Cuisinart DFP-14BCN Buttons Replacement: 9 단계, 이미지 2/2
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Buttons Replacement, Buttons: 10 단계, 이미지 1/3 Cuisinart DFP-14BCN Buttons Replacement, Buttons: 10 단계, 이미지 2/3 Cuisinart DFP-14BCN Buttons Replacement, Buttons: 10 단계, 이미지 3/3
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Buttons Replacement: 11 단계, 이미지 1/2 Cuisinart DFP-14BCN Buttons Replacement: 11 단계, 이미지 2/2
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Buttons Replacement: 12 단계, 이미지 1/1
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Buttons Replacement: 13 단계, 이미지 1/3 Cuisinart DFP-14BCN Buttons Replacement: 13 단계, 이미지 2/3 Cuisinart DFP-14BCN Buttons Replacement: 13 단계, 이미지 3/3
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sonya Dick
회원 가입일: 10/05/16
352 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-3, Livingston Fall 2016 Cal Poly, Team 10-3, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G3
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Is there a source for replacing the button assembly?
BadMahoney - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 14
전체 시간: 1,098
