메인 콘텐츠로 스킵하기
  1. Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
    • Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
  2. Remove the black plastic covering from the motor base.
    • Remove the black plastic covering from the motor base.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Locate the connections between the power cord and the brown and white wires. Cut off these connections.
    • Locate the connections between the power cord and the brown and white wires. Cut off these connections.
  5. Strip the plastic coating off the edge of the brown and white wires using a wire stripper.
    • Strip the plastic coating off the edge of the brown and white wires using a wire stripper.
  6. Create a connection between the brown and white wires and the wires of the new power cord by soldering them together.
    • Create a connection between the brown and white wires and the wires of the new power cord by soldering them together.
  7. Fit the wires back into the motor base and place the new power cord in the slot.
    • Fit the wires back into the motor base and place the new power cord in the slot.
결론
By the end of this guide< you will have successfully replaced the power cord to your device.
다른 한 분이 해당 안내서를 완성하였습니다.
Reagan Burns
회원 가입일: 2015년 04월 02일
119 평판
안내서 1개 작성함
Cal Poly, Team 24-1, Lancaster Spring 2015 Cal Poly, Team 24-1, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G1
2 회원들
안내서 1개 작성하였습니다
I can't get a replacement cord from cuisinart. Where can I buy one the same?
Elizabeth - 답글
I need one also. drshtender1@gmail.com
Feivel Garnick -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 4
지난 30일: 6
전체 시간: 780
