주요 콘텐츠로 건너뛰기
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement
필요한 것
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement, Power Cord: 1 단계, 이미지 1/1
    • Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 2 단계, 이미지 1/1
    • Remove the black plastic covering from the motor base.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 3 단계, 이미지 1/1
    • Locate the connections between the power cord and the brown and white wires. Cut off these connections.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 4 단계, 이미지 1/1
    • Strip the plastic coating off the edge of the brown and white wires using a wire stripper.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 5 단계, 이미지 1/1
    • Create a connection between the brown and white wires and the wires of the new power cord by soldering them together.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 6 단계, 이미지 1/1
    • Fit the wires back into the motor base and place the new power cord in the slot.
결론
By the end of this guide< you will have successfully replaced the power cord to your device.
다른 한 분이 해당 안내서를 완성하였습니다.
Reagan Burns
회원 가입일: 04/02/15
119 평판
안내서 1개 작성함
Cal Poly, Team 24-1, Lancaster Spring 2015 Cal Poly, Team 24-1, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G1
2 회원들
안내서 1개 작성하였습니다
댓글 4개
I can't get a replacement cord from cuisinart. Where can I buy one the same?
Elizabeth - 답글
I need one also. drshtender1@gmail.com
Feivel Garnick -
Where can you buy the replacement cord?
ruby48lp - 답글
There's not an exact replacement from Cuisinart, but a two prong replacement will work. I found one "Lamp Cord Set - Black - PLT 56-1854-50 | 1000Bulbs.com" https://www.1000bulbs.com/product/137344... that would work.
Riley Carns - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 1,621
