주요 콘텐츠로 건너뛰기
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement
필요한 것
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement, Switch: 1 단계, 이미지 1/1
    • Remove the four screws (circled in red) out of the bottom of the processor using a Philips #2 Screwdriver.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: 2 단계, 이미지 1/1
    • Remove the bottom casing of the food processor and set aside.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: 3 단계, 이미지 1/1
    • Remove the four screws (circled in red) holding the switch down.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: 4 단계, 이미지 1/1
    • Carefully pull the switch out of the device.
    • This step may take some time.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: 5 단계, 이미지 1/1
    • Remove the two screws from the switch (circled in red) attached by wires.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: 6 단계, 이미지 1/1
    • Remove the component (shown by the arrow in the picture to the left) attached to wires from the switch.
  7. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: 7 단계, 이미지 1/1
    • Carefully remove and replace the switch, now that the wires are detached.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Riley Carns
회원 가입일: 04/02/15
279 평판
안내서 2개 작성하였습니다
Cal Poly, Team 24-1, Lancaster Winter 2015 Cal Poly, Team 24-1, Lancaster Winter 2015 회원
CPSU-LANCASTER-W15S24G1
1 회원
안내서 2개 작성하였습니다
댓글 9개
Thanks for the guide. Where did you get the replacement switch? Thanks
Fran Fedoroff - 답글
Hey Riley,
Looks good, but where do I buy a replacement switch?
Margaret Mealia - 답글
Yes, where does one buy a switch?
Lori Girard - 답글
I recently disassembled my 25+ year old dcl10plus after no parts sites showed a “switch” before finding this website posting.
Turns out (as is clear in the posting) the actual electrical part of switch is not some fancy gizmo but a simple micro switch in a fancy gizmo.
The original is no longer made and is actually a very plain Jane switch. I found many expensive replacements that were typically $3-5 plus $7-8 shipping. A friend suggested checking banggood and found them sold in lots of 1, 2, 5, 10, 20 starting at about $1.50 including shipping but switch had additional “roller arm” which I assumed would just pop out. I order the two pack at $1.88.
The banggood search id on the item is 944612. I actually had to use a small hack saw to cut the arm as it didn’t pop out. Mine was a DCL10p the switch may vary in other models so disassemble before ordering. Also beware if you look at other sites … there are two sizes of electrical lugs that I saw on this size switch … this is the smaller one (match yours to banggod picture).
Terry Schwarz - 답글
I am hoping to find not the microswitch, but the plastic lever. How would you go about finding a replacement for that? Ours broke and we can turn the Cuisanart on/off by jamming a wooden spoon in there. There must be a better replacement though…
Bswx - 답글
The problem I had was the switch was getting stuck in the ON position. I replaced the original micro-switch Omron V-21-1C8 with Omron V-21-1C6. Ordered it from DIGIKEY - the switch costs $5.70 + $4.99 for shipping.
It fits and works perfectly, no modification was required.
Miron Vislocky - 답글
Can you give some tips how to pull the switch out of the device, step 4? I have hard time with this step. It seems is not enough space to pull it out
roangel17 - 답글
Actually I managed to take it out and cleaned it. Seems food was stuck on it. It works now! Thank you so much. You are the only place I found a fixing guide.
roangel17 - 답글
Where I can buy the switch in case this one doesn’t work after a while?
roangel17 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 11
전체 시간: 1,931
