주요 콘텐츠로 건너뛰기
Cuisinart DLC-8F Automatic Circuit Breaker Replacement
필요한 것
  1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: 1 단계, 이미지 1/2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: 1 단계, 이미지 2/2
    • Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
  2. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 2 단계, 이미지 1/2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 2 단계, 이미지 2/2
    • Gently lift the bottom cover from the main body.
  3. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 3 단계, 이미지 1/1
    • Remove the two 62 mm Phillips #2 screws from the cable retaining clip.
  4. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 4 단계, 이미지 1/2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 4 단계, 이미지 2/2
    • Lift off the cable retaining
  5. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 5 단계, 이미지 1/2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 5 단계, 이미지 2/2
    • Pull apart the two wires of the power cable at their connections as shown.
  6. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 6 단계, 이미지 1/2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 6 단계, 이미지 2/2
    • Lift out the cable.
  7. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: 7 단계, 이미지 1/3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: 7 단계, 이미지 2/3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: 7 단계, 이미지 3/3
    • Pull out the power cable screw stand with your hand.
  8. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 8 단계, 이미지 1/2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 8 단계, 이미지 2/2
    • Remove the two 15 mm Phillips #2 screws on the automatic circuit breaker.
  9. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 9 단계, 이미지 1/2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 9 단계, 이미지 2/2
    • Pull out the automatic circuit breaker with your hand.
  10. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 10 단계, 이미지 1/3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 10 단계, 이미지 2/3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: 10 단계, 이미지 3/3
    • Pull off the three wires by grabbing from the base of the wire.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Colman
회원 가입일: 01/25/17
573 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-6, Banghart Winter 2017 Cal Poly, Team 8-6, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G6
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 15
전체 시간: 576
