소개
This guide teaches the user how to replace the safety switch in your Cuisinart DLC-8F. The removal of the safety switch first requires the removal of the bottom hood and all of this can be done with just a Phillips #2 screwdriver. This is an easy process and should only take about 10 minutes.
필요한 것
Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
다른 2명이 해당 안내서를 완성하였습니다.
