소개
This repair/ replacement may be needed if the lettering on the knobs have worn off or if the knobs have been snapped off.
필요한 것
Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
The aligned parts will allow the cooking surfaces to work properly.
Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
Move the circuit board to the side so it is out of the way.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 15개
Where do you find the replacement knobs?
Wish I knew! I need two knobs. Are their universal knobs out there that can be substituted?
sfk -
im in same boat can't find the dials/knobs- 2 of mine are broken and useless
I have several cuisinart appliances. I won't ever buy another. I need one replacement knob, the best they can do is 20 percent off on a new griddler . I can get that from bed bath and beyond. Thanks cuisinart, finding new brands. Cuisinart is dead to me.
