소개
If the indication lights on the Cuisinart Griddler GR- 4N have stopped working when your device is in use then the this guide will help you replace the LED lights.
필요한 것
Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
The aligned parts will allow the cooking surfaces to work properly.
Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
Move the circuit board to the side so it is out of the way.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 4개
Hai
is there any body can come home and help me
or any place I can send my machine and repair
regds
Leela Manilal
any tips on how to fix a broken thermostat?
Will any green LED work? Or does it have to be a particular voltage?
How do I get the heating element off? It seems pretty securely connected via the red and white wires connected to the machine. Is there an easy way to disassemble this part? I honestly just want to clean the baked on grease on the pans but I’ve got to remove the heating element in order to do that. Any advice would be most appreciated. Thanks!
