주요 콘텐츠로 건너뛰기
Cuisinart Griddler GR- 4N LED Light Replacement
필요한 것
  1. Cuisinart Griddler GR- 4N LED Light  Replacement, Cooking Surfaces: 1 단계, 이미지 1/2 Cuisinart Griddler GR- 4N LED Light  Replacement, Cooking Surfaces: 1 단계, 이미지 2/2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR- 4N LED Light  Replacement: 2 단계, 이미지 1/1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR- 4N LED Light  Replacement: 3 단계, 이미지 1/1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR- 4N LED Light  Replacement: 4 단계, 이미지 1/1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR- 4N LED Light  Replacement: 5 단계, 이미지 1/2 Cuisinart Griddler GR- 4N LED Light  Replacement: 5 단계, 이미지 2/2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  6. Cuisinart Griddler GR- 4N LED Light  Replacement, Cuisinart Griddler GR- 4N Disassembly: 6 단계, 이미지 1/1
    • Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
    • Move the circuit board to the side so it is out of the way.
  7. Cuisinart Griddler GR- 4N LED Light  Replacement: 7 단계, 이미지 1/1
    • Remove the two 6 mm Phillips #2 screws that secure the white plastic LED holder.
  8. Cuisinart Griddler GR- 4N LED Light  Replacement, LED Light: 8 단계, 이미지 1/2 Cuisinart Griddler GR- 4N LED Light  Replacement, LED Light: 8 단계, 이미지 2/2
    • Cut the zip ties which hold the LED lights in place with scissors/knife.
  9. Cuisinart Griddler GR- 4N LED Light  Replacement: 9 단계, 이미지 1/2 Cuisinart Griddler GR- 4N LED Light  Replacement: 9 단계, 이미지 2/2
    • Slide back black plastic covers and cut the two wires connected to the LED with a pair of scissors.
    • The LED bulb should now be free to remove. In order to replace bulb you must solder the new LED into the existing wires.
    • Upon soldering the LED will need to be zip tied back in place.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kayla Londono
회원 가입일: 04/15/16
632 평판
안내서 4개 작성하였습니다
Cal Poly, Team 1-12, Maness Spring 2016 Cal Poly, Team 1-12, Maness Spring 2016 회원
CPSU-MANESS-S16S1G12
4 회원들
안내서 6개 작성하였습니다
댓글 4개
Hai
is there any body can come home and help me
or any place I can send my machine and repair
regds
Leela Manilal
Raghavan Manilal - 답글
any tips on how to fix a broken thermostat?
Jean-Michel Léon - 답글
Will any green LED work? Or does it have to be a particular voltage?
Bob Mounger - 답글
How do I get the heating element off? It seems pretty securely connected via the red and white wires connected to the machine. Is there an easy way to disassemble this part? I honestly just want to clean the baked on grease on the pans but I’ve got to remove the heating element in order to do that. Any advice would be most appreciated. Thanks!
Katie Hoppmann - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 14
전체 시간: 1,254
