주요 콘텐츠로 건너뛰기
Cuisinart Griddler GR-4N Cooking Surfaces Replacement
필요한 것
  1. Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: 1 단계, 이미지 1/2 Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: 1 단계, 이미지 2/2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: 2 단계, 이미지 1/1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: 3 단계, 이미지 1/1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: 4 단계, 이미지 1/1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: 5 단계, 이미지 1/2 Cuisinart Griddler GR-4N Cooking Surfaces Replacement: 5 단계, 이미지 2/2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kayla Londono
회원 가입일: 04/15/16
632 평판
안내서 4개 작성하였습니다
Cal Poly, Team 1-12, Maness Spring 2016 Cal Poly, Team 1-12, Maness Spring 2016 회원
CPSU-MANESS-S16S1G12
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
The 'cooking plates' on my unit always fall off. I tried bending the tabs to make it tighter - did not help. Any ideas?
M S - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 33
전체 시간: 4,043
