소개
Use this guide to replace the "Chop" and "Grind" buttons located on the Cuisinart Mini-Prep DLC-2A.
필요한 것
Remove the back panel using a Phillips #1 Screwdriver on the four screws that hold it in place.
Locate the Button Panel inside the blender.
Using your Phillips #1 Screwdriver, remove the two screws which hold the panel in place.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
