주요 콘텐츠로 건너뛰기
Cuisinart Mini-Prep DLC-2A Button Replacement
필요한 것
  1. Cuisinart Mini-Prep DLC-2A Button Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: 1 단계, 이미지 1/2 Cuisinart Mini-Prep DLC-2A Button Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: 1 단계, 이미지 2/2
    • Remove the back panel using a Phillips #1 Screwdriver on the four screws that hold it in place.
  2. Cuisinart Mini-Prep DLC-2A Button Replacement, Button: 2 단계, 이미지 1/1
    • Locate the Button Panel inside the blender.
    • Using your Phillips #1 Screwdriver, remove the two screws which hold the panel in place.
  3. Cuisinart Mini-Prep DLC-2A Button Replacement: 3 단계, 이미지 1/3 Cuisinart Mini-Prep DLC-2A Button Replacement: 3 단계, 이미지 2/3 Cuisinart Mini-Prep DLC-2A Button Replacement: 3 단계, 이미지 3/3
    • Locate the black box held in place on the panel.
    • Using your Spudger, wedge the black box out of its place to uncover the button
  4. Cuisinart Mini-Prep DLC-2A Button Replacement: 4 단계, 이미지 1/2 Cuisinart Mini-Prep DLC-2A Button Replacement: 4 단계, 이미지 2/2
    • Once the black box is out of place, use your finger to push out the button.
    • Now replace the old button with your newly acquired button.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Xavier Tapia
회원 가입일: 09/25/17
144 평판
안내서 1개 작성함
댓글 한 개
Hi,
Where’d you get the new buttons?
Mark B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 266
