주요 콘텐츠로 건너뛰기
Cuisinart Smart Stick CSB-75 Electrical Cord Replacement
필요한 것
  1. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: 1 단계, 이미지 1/3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: 1 단계, 이미지 2/3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: 1 단계, 이미지 3/3
    • Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
    • After prying these off, the screws will be exposed.
  2. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 2 단계, 이미지 1/2 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 2 단계, 이미지 2/2
    • Remove three 13.3 mm Phillips PH#2 screws.
  3. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 3 단계, 이미지 1/3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 3 단계, 이미지 2/3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 3 단계, 이미지 3/3
    • Pry open Cuisinart using a plastic opening tool.
    • The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Make sure to pry open near the clips of the smart stick for easy opening.
  4. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 4 단계, 이미지 1/3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 4 단계, 이미지 2/3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 4 단계, 이미지 3/3
    • Unscrew the 4 screws on the inside.
    • Remove 2 13.3mm Phillips PH#2 screws.
    • Remove 2 17.5 mm Phillips PH#2 screws.
    • Unscrewing these screws will isolate the switch board.
  5. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 5 단계, 이미지 1/3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 5 단계, 이미지 2/3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: 5 단계, 이미지 3/3
    • Refer to these steps on Soldering to replace the electrical cord in the smart stick.
    • Be careful when soldering; it gets very hot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordan Robinson
회원 가입일: 09/02/15
542 평판
안내서 4개 작성하였습니다
USF Tampa, Team 16-2, Wollert Fall 2015 USF Tampa, Team 16-2, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 1,287
