이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will teach you how to replace the switch board inside your Cuisinart Smart Stick. If power is not being supplied to the Smart Stick, the electrical cord could be faulty.
필요한 것
Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
After prying these off, the screws will be exposed.
다른 한 분이 해당 안내서를 완성하였습니다.
