주요 콘텐츠로 건너뛰기
Cuisinart TOA-60FR Light Switch Spring Replacement
필요한 것
  1. Cuisinart TOA-60FR Light Switch Spring Replacement, Outside removal: 1 단계, 이미지 1개 중 1개
    • Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
  2. Cuisinart TOA-60FR Light Switch Spring Replacement: 2 단계, 이미지 2개 중 1개 Cuisinart TOA-60FR Light Switch Spring Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
    • Pull off the back panel.
  3. Cuisinart TOA-60FR Light Switch Spring Replacement: 3 단계, 이미지 3개 중 1개 Cuisinart TOA-60FR Light Switch Spring Replacement: 3 단계, 이미지 3개 중 2개 Cuisinart TOA-60FR Light Switch Spring Replacement: 3 단계, 이미지 3개 중 3개
    • Flip the oven upside down.
    • Use a spudger to pull out the grey stoppers.
    • Use a Phillips #1 screwdriver to remove all three 11 mm screws.
  4. Cuisinart TOA-60FR Light Switch Spring Replacement: 4 단계, 이미지 2개 중 1개 Cuisinart TOA-60FR Light Switch Spring Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
  5. Cuisinart TOA-60FR Light Switch Spring Replacement: 5 단계, 이미지 3개 중 1개 Cuisinart TOA-60FR Light Switch Spring Replacement: 5 단계, 이미지 3개 중 2개 Cuisinart TOA-60FR Light Switch Spring Replacement: 5 단계, 이미지 3개 중 3개
    • Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
  6. Cuisinart TOA-60FR Light Switch Spring Replacement, Light Switch Spring: 6 단계, 이미지 2개 중 1개 Cuisinart TOA-60FR Light Switch Spring Replacement, Light Switch Spring: 6 단계, 이미지 2개 중 2개
    • Unscrew these two screws to detach the light switch from the panel.
  7. Cuisinart TOA-60FR Light Switch Spring Replacement: 7 단계, 이미지 2개 중 1개 Cuisinart TOA-60FR Light Switch Spring Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the back piece of the switch off of the clicking piece.
  8. Cuisinart TOA-60FR Light Switch Spring Replacement: 8 단계, 이미지 2개 중 1개 Cuisinart TOA-60FR Light Switch Spring Replacement: 8 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry open the clicking piece.
  9. Cuisinart TOA-60FR Light Switch Spring Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the broken spring and replace it with the new one.
결론
작성자
5다른 기여자 명과 함께
Myra Chirchirillo
회원 가입일: 09/08/23
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 19
전체 시간: 427
