주요 콘텐츠로 건너뛰기
Cuisinart TOA-60FR Lightbulb Replacement
필요한 것
  1. Cuisinart TOA-60FR Lightbulb Replacement, Outside removal: 1 단계, 이미지 1/1
    • Using a 25-hexagon head, unscrew these 7.31 mm three screws.
  2. Cuisinart TOA-60FR Lightbulb Replacement: 2 단계, 이미지 1/2 Cuisinart TOA-60FR Lightbulb Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
    • Pull off the back.
  3. Cuisinart TOA-60FR Lightbulb Replacement: 3 단계, 이미지 1/3 Cuisinart TOA-60FR Lightbulb Replacement: 3 단계, 이미지 2/3 Cuisinart TOA-60FR Lightbulb Replacement: 3 단계, 이미지 3/3
    • Flip the oven upside down.
    • Pick the grey stoppers out with a sprudger.
    • Using a Phillips #1 screwdriver, remove these three 11 mm screws.
  4. Cuisinart TOA-60FR Lightbulb Replacement: 4 단계, 이미지 1/2 Cuisinart TOA-60FR Lightbulb Replacement: 4 단계, 이미지 2/2
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the device.
  5. Cuisinart TOA-60FR Lightbulb Replacement: 5 단계, 이미지 1/3 Cuisinart TOA-60FR Lightbulb Replacement: 5 단계, 이미지 2/3 Cuisinart TOA-60FR Lightbulb Replacement: 5 단계, 이미지 3/3
    • Pull the top piece off.
    • Push down before pulling up to release the tabs.
  6. Cuisinart TOA-60FR Lightbulb Replacement, Lightbulb: 6 단계, 이미지 1/2 Cuisinart TOA-60FR Lightbulb Replacement, Lightbulb: 6 단계, 이미지 2/2
    • Remove these two 12.8 mm screws at the top on each side.
    • Remove two 12.8 mm screws at the bottom, as demonstrated in the first picture.
    • You should now be able to push the back out with the four screws removed to see the light bulb.
  7. Cuisinart TOA-60FR Lightbulb Replacement: 7 단계, 이미지 1/1
    • Remove these four screws.
    • Pull the light away from it's window.
  8. Cuisinart TOA-60FR Lightbulb Replacement: 8 단계, 이미지 1/2 Cuisinart TOA-60FR Lightbulb Replacement: 8 단계, 이미지 2/2
    • Using a wrench, remove the washer.
    • Pull the silver casing off the lightbulb.
  9. Cuisinart TOA-60FR Lightbulb Replacement: 9 단계, 이미지 1/2 Cuisinart TOA-60FR Lightbulb Replacement: 9 단계, 이미지 2/2
    • Now unscrew the lightbulb to replace it with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anastasia Hopkins
회원 가입일: 09/08/23
362 평판
안내서 3개 작성하였습니다
University of New Orleans, Team 4-6, McDonald Fall 2023 University of New Orleans, Team 4-6, McDonald Fall 2023 회원
UNO-MCDONALD-F23S4G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 40
전체 시간: 169
