소개
Are you having trouble with a flickering light bulb in your Cuisinart TOA-60FR? If so, this guide will help you know if you need to replace your lightbulb or find other solutions.
Make sure you set aside a fair amount of time to complete this; even if you replace your lightbulb, it isn't easy without removing the whole outside of the device. The lightbulb illuminates the entire toaster oven; it may appear insignificant, but it is an essential component.
필요한 것
Remove these two 12.8 mm screws at the top on each side.
Remove two 12.8 mm screws at the bottom, as demonstrated in the first picture.
다른 한 분이 해당 안내서를 완성하였습니다.
