주요 콘텐츠로 건너뛰기
Cuisinart TOA-60FR Power Cord Replacement
필요한 것
  1. Cuisinart TOA-60FR Power Cord Replacement, Outside removal: 1 단계, 이미지 1/1
    • Using a 25-hexagon head, unscrew these 7.31 mm three screws.
  2. Cuisinart TOA-60FR Power Cord Replacement: 2 단계, 이미지 1/2 Cuisinart TOA-60FR Power Cord Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
    • Pull off the back.
  3. Cuisinart TOA-60FR Power Cord Replacement: 3 단계, 이미지 1/3 Cuisinart TOA-60FR Power Cord Replacement: 3 단계, 이미지 2/3 Cuisinart TOA-60FR Power Cord Replacement: 3 단계, 이미지 3/3
    • Flip the oven upside down.
    • Pick the grey stoppers out with a sprudger.
    • Using a Phillips #1 screwdriver, remove these three 11 mm screws.
  4. Cuisinart TOA-60FR Power Cord Replacement: 4 단계, 이미지 1/2 Cuisinart TOA-60FR Power Cord Replacement: 4 단계, 이미지 2/2
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the device.
  5. Cuisinart TOA-60FR Power Cord Replacement: 5 단계, 이미지 1/3 Cuisinart TOA-60FR Power Cord Replacement: 5 단계, 이미지 2/3 Cuisinart TOA-60FR Power Cord Replacement: 5 단계, 이미지 3/3
    • Pull the top piece off.
    • Push down before pulling up to release the tabs.
  6. Cuisinart TOA-60FR Power Cord Replacement, Power Cord: 6 단계, 이미지 1/1
    • Take the needle nose pliers and cut off the crimped-on-wire connectors.
    • Pressed down hard. These wires are thick.
    • These are crimped on wire conncetors so they can not be twisted off. The only way to remove them is by cutting off the wire.
  7. Cuisinart TOA-60FR Power Cord Replacement: 7 단계, 이미지 1/3 Cuisinart TOA-60FR Power Cord Replacement: 7 단계, 이미지 2/3 Cuisinart TOA-60FR Power Cord Replacement: 7 단계, 이미지 3/3
    • Strip the wires back with wire strippers. Or carefully take the needle nose pliers and cut gently to only make a mark on the jacket and not the wires. Then pull with the pliers to remove the jacket.
  8. Cuisinart TOA-60FR Power Cord Replacement: 8 단계, 이미지 1/3 Cuisinart TOA-60FR Power Cord Replacement: 8 단계, 이미지 2/3 Cuisinart TOA-60FR Power Cord Replacement: 8 단계, 이미지 3/3
    • Take the white, blue, and black wire together and push togther
    • Then take the pliers and twist them until they are all combined.
  9. Cuisinart TOA-60FR Power Cord Replacement: 9 단계, 이미지 1/2 Cuisinart TOA-60FR Power Cord Replacement: 9 단계, 이미지 2/2
    • Crimp the wire connector with a crimper or pliers
결론
Anastasia Hopkins
회원 가입일: 09/08/23
362 평판
안내서 3개 작성하였습니다
University of New Orleans, Team 4-6, McDonald Fall 2023 University of New Orleans, Team 4-6, McDonald Fall 2023 회원
UNO-MCDONALD-F23S4G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 47
전체 시간: 182
