주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cummins X15 Engine Component Inspection and Teardown Insights
필요한 것
동영상 개요
  1. Cummins X15 Engine Component Inspection and Teardown Insights, Cummins X15 Engine Component Inspection and Teardown Insights: 1 단계, 이미지 2개 중 1개 Cummins X15 Engine Component Inspection and Teardown Insights, Cummins X15 Engine Component Inspection and Teardown Insights: 1 단계, 이미지 2개 중 2개
    • First, remove the cylinder head. The X15's cylinder head has a 24-valve arrangement and a double overhead camshaft (DOHC) structure (a single overhead camshaft structure is also available). Then we can see the X15 engine's valve rocker arms. The entire engine has a total of 18 rocker arms,the valve rocker arm and the fuel injector rocker arm.
    댓글 쓰기
  2. Cummins X15 Engine Component Inspection and Teardown Insights: 2 단계, 이미지 2개 중 1개 Cummins X15 Engine Component Inspection and Teardown Insights: 2 단계, 이미지 2개 중 2개
    • Step 2: Engine Block and Piston Inspection With the CUMMINS X15 head removed, we can inspect the pistons and combustion chambers. This is the critical stage to check the head gasket mounting surface for leaks and analyze carbon buildup on the piston crowns, which can indicate fuel injector health or oil consumption issues.
    댓글 쓰기
  3. Cummins X15 Engine Component Inspection and Teardown Insights: 3 단계, 이미지 2개 중 1개 Cummins X15 Engine Component Inspection and Teardown Insights: 3 단계, 이미지 2개 중 2개
    • Step 3: Bottom End Inspection (Crankshaft & Rods) After removing the oil pan, we can inspect the CUMMINS X15's rotating assembly. Check the crankshaft and connecting rods for signs of overheating or bearing wear. This view also allows us to examine the cylinder liner skirts for cracks or unusual friction marks.
    댓글 쓰기
결론
Proper installation of the X15 cylinder head is critical for engine longevity. Always ensure the block surface is perfectly clean and flat. For specific torque sequences and the full digital service manual, visit our technical library at YZDL Parts."
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Steven Shi
회원 가입일: 03/24/26
193 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 12
전체 시간: 25
