주요 콘텐츠로 건너뛰기
Cupboard Drawer handle Replacement
필요한 것
  1. Cupboard Drawer handle Replacement, Handle: 1 단계, 이미지 1/1
    • Remove the drawer from the cupboard and empty the contents.
  2. Cupboard Drawer handle Replacement: 2 단계, 이미지 1/1
    • Tighten the good side of the handle by rotating the screwdriver in a clockwise direction.
  3. Cupboard Drawer handle Replacement: 3 단계, 이미지 1/3 Cupboard Drawer handle Replacement: 3 단계, 이미지 2/3 Cupboard Drawer handle Replacement: 3 단계, 이미지 3/3
    • Take a screw with a similar radius of the handle’s hole for the drawer.
  4. Cupboard Drawer handle Replacement: 4 단계, 이미지 1/3 Cupboard Drawer handle Replacement: 4 단계, 이미지 2/3 Cupboard Drawer handle Replacement: 4 단계, 이미지 3/3
    • Line up the hole or holes on the back of the handle with the holes in the front plate of the drawer.
    • Take the screw and insert it in the hole at the back of the drawer.
  5. Cupboard Drawer handle Replacement: 5 단계, 이미지 1/3 Cupboard Drawer handle Replacement: 5 단계, 이미지 2/3 Cupboard Drawer handle Replacement: 5 단계, 이미지 3/3
    • Adjust the screw in a way that it stays in a straight line.
    • Slowly rotate the screw clockwise and in a straight position so that the handle stays erect.
  6. Cupboard Drawer handle Replacement: 6 단계, 이미지 1/2 Cupboard Drawer handle Replacement: 6 단계, 이미지 2/2
    • Make sure to check the grip of the handle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Raisa Jahan
회원 가입일: 07/06/21
160 평판
안내서 1개 작성함
York University, Team S17-G1, Allen Summer 2021 York University, Team S17-G1, Allen Summer 2021 회원
YORK-ALLEN-SU21S17G1
1 회원
안내서 1개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 24
전체 시간: 247
