주요 콘텐츠로 건너뛰기
Cyber-Shot DSC-H55 Battery Replacement
  1. Cyber-Shot DSC-H55 Battery Replacement, Finding the battery compartment: 1 단계, 이미지 1/2 Cyber-Shot DSC-H55 Battery Replacement, Finding the battery compartment: 1 단계, 이미지 2/2
    • Before you begin it is important to know where the battery compartment is. The battery compartment is located on the bottom of the camera.
    • Place the camera upside down with the lens facing you so that the battery compartment is facing up.
    • Place your thumb on the lid of the battery compartment making sure you put some pressure.
  2. Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: 2 단계, 이미지 1/3 Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: 2 단계, 이미지 2/3 Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: 2 단계, 이미지 3/3
    • Grab the camera with one hand, with your thumb still on the lid, apply pressure and slide to the right.
    • Lift the lid, exposing the battery and SD slot.
  3. Cyber-Shot DSC-H55 Battery Replacement, Removing Battery: 3 단계, 이미지 1/1
    • There is a small blue tab on the right of the compartment. In order to remove the battery, move this tab aside and the battery will pop up.
  4. Cyber-Shot DSC-H55 Battery Replacement, Inserting a New Battery: 4 단계, 이미지 1/2 Cyber-Shot DSC-H55 Battery Replacement, Inserting a New Battery: 4 단계, 이미지 2/2
    • Grab the new battery. Place the battery so that the arrow is pointing down and facing you. Next, slide the the battery into the battery compartment.
    • The blue tab will lock the battery into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jazmin Young
회원 가입일: 01/21/15
608 평판
안내서 5개 작성하였습니다
USF Tampa, Team 6-2, Brown Winter 2015 USF Tampa, Team 6-2, Brown Winter 2015 회원
USFT-BROWN-W15S6G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 1,008
