소개
To remove the disc tray bracket, you must first remove the top panel of the DVD, which exposes the disc tray bracket. The Disc tray bracket sits on top of the disc tray to keep the disc in place while in use.
도구
부품
부품은 필요하지 않습니다.
Unplug the DVD player from the wall socket.
Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray.
다른 2명이 해당 안내서를 완성하였습니다.
