주요 콘텐츠로 건너뛰기
CyberHome CH-DVD 300 Disc Tray Replacement
필요한 것
  1. CyberHome CH-DVD 300 Disc Tray Replacement, Top Panel: 1 단계, 이미지 1/2 CyberHome CH-DVD 300 Disc Tray Replacement, Top Panel: 1 단계, 이미지 2/2
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. CyberHome CH-DVD 300 Disc Tray Replacement: 2 단계, 이미지 1/2 CyberHome CH-DVD 300 Disc Tray Replacement: 2 단계, 이미지 2/2
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. CyberHome CH-DVD 300 Disc Tray Replacement, Back Panel: 3 단계, 이미지 1/2 CyberHome CH-DVD 300 Disc Tray Replacement, Back Panel: 3 단계, 이미지 2/2
    • Remove the remaining screws on the back of the DVD player:
    • There will be four 15 mm screws and two 6.3 mm screws.
  4. CyberHome CH-DVD 300 Disc Tray Replacement: 4 단계, 이미지 1/1
    • Remove the back panel by:
    • Lifting up on the back panel.
    • Pulling the back panel backwards from the DVD player.
  5. CyberHome CH-DVD 300 Disc Tray Replacement, Disc Tray: 5 단계, 이미지 1/3 CyberHome CH-DVD 300 Disc Tray Replacement, Disc Tray: 5 단계, 이미지 2/3 CyberHome CH-DVD 300 Disc Tray Replacement, Disc Tray: 5 단계, 이미지 3/3
    • Remove the four 8.1mm screws in each of the corners of the disc tray.
  6. CyberHome CH-DVD 300 Disc Tray Replacement: 6 단계, 이미지 1/2 CyberHome CH-DVD 300 Disc Tray Replacement: 6 단계, 이미지 2/2
    • Orient the device so the front is facing towards you. Remove the disc tray faceplate by lifting up on both corners firmly.
    • The faceplate is located on the front of the DVD player and will prevent the disc tray removal if not removed.
  7. CyberHome CH-DVD 300 Disc Tray Replacement: 7 단계, 이미지 1/2 CyberHome CH-DVD 300 Disc Tray Replacement: 7 단계, 이미지 2/2
    • Detach the ribbon cable from the side of the DVD player by gently pulling it out.
  8. CyberHome CH-DVD 300 Disc Tray Replacement: 8 단계, 이미지 1/1
    • Orient the device so the back is facing towards you. Remove the disk tray out towards the back of the DVD player by lifting it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Menezes
회원 가입일: 04/07/14
642 평판
안내서 5개 작성하였습니다
Cal Poly, Team 6-5, Forte Spring 2014 Cal Poly, Team 6-5, Forte Spring 2014 회원
CPSU-FORTE-S14S6G5
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
Bom dia. gostaria de obter informação sobre a referência desse componente CI u7 da placa ficarei muito grato
Gilvando - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 19
전체 시간: 1,685
