주요 콘텐츠로 건너뛰기
CyberPower UPS Battery Replacement
필요한 것
  1. CyberPower UPS Battery Replacement, Battery: 1 단계, 이미지 1/2 CyberPower UPS Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Power down the unit by pressing the power button until the display goes black.
    • This is usually about 3 seconds.
    • Unplug the power cord from the wall outlet.
  2. CyberPower UPS Battery Replacement: 2 단계, 이미지 1/3 CyberPower UPS Battery Replacement: 2 단계, 이미지 2/3 CyberPower UPS Battery Replacement: 2 단계, 이미지 3/3
    • Remove the battery plate cover at the bottom of the UPS using a Phillips #1 screwdriver.
    • If the screwdriver is not magnetized, tap on the cover plate to completely remove the screw.
  3. CyberPower UPS Battery Replacement: 3 단계, 이미지 1/2 CyberPower UPS Battery Replacement: 3 단계, 이미지 2/2
    • Slide the battery cover plate to the left.
    • Grasp the battery plate cover and lift it off the the UPS.
  4. CyberPower UPS Battery Replacement: 4 단계, 이미지 1/3 CyberPower UPS Battery Replacement: 4 단계, 이미지 2/3 CyberPower UPS Battery Replacement: 4 단계, 이미지 3/3
    • Pull out the battery to expose the terminal connectors.
    • Use needlenose pliers to disconnect both battery terminal connectors.
    • Do not pull the connectors by the wires, pull connectors by grabbing the connector itself.
    • With the battery terminal connectors disconnected, slide the battery all the way out.
  5. CyberPower UPS Battery Replacement: 5 단계, 이미지 1/3 CyberPower UPS Battery Replacement: 5 단계, 이미지 2/3 CyberPower UPS Battery Replacement: 5 단계, 이미지 3/3
    • The replacement battery should be a 12 volt, 9 amp-hour, sealed lead acid battery with f2 type connectors.
    • Install the new battery and reconnect the terminals.
  6. CyberPower UPS Battery Replacement: 6 단계, 이미지 1/3 CyberPower UPS Battery Replacement: 6 단계, 이미지 2/3 CyberPower UPS Battery Replacement: 6 단계, 이미지 3/3
    • Insert the screw to secure the battery cover plate.
    • Tighten the screw with a Phillips #1 screwdriver.
  7. CyberPower UPS Battery Replacement: 7 단계, 이미지 1/3 CyberPower UPS Battery Replacement: 7 단계, 이미지 2/3 CyberPower UPS Battery Replacement: 7 단계, 이미지 3/3
    • Plug system into the wall outlet.
    • Press the power button to turn on the unit.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jervon Stuart
회원 가입일: 10/07/20
169 평판
안내서 1개 작성함
University of Memphis, Team S3-G8, Willis Fall 2020 University of Memphis, Team S3-G8, Willis Fall 2020 회원
UM-WILLIS-F20S3G8
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 73
30일 전: 316
전체 시간: 12,680
