주요 콘텐츠로 건너뛰기
CyberPower UPS Battery Replacement
필요한 것
  1. CyberPower UPS Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 CyberPower UPS Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Power down the unit by pressing the power button until the display goes black.
    • This is usually about 3 seconds.
    • Unplug the power cord from the wall outlet.
  2. CyberPower UPS Battery Replacement: 2 단계, 이미지 3개 중 1개 CyberPower UPS Battery Replacement: 2 단계, 이미지 3개 중 2개 CyberPower UPS Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the battery plate cover at the bottom of the UPS using a Phillips #1 screwdriver.
    • If the screwdriver is not magnetized, tap on the cover plate to completely remove the screw.
  3. CyberPower UPS Battery Replacement: 3 단계, 이미지 2개 중 1개 CyberPower UPS Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the battery cover plate to the left.
    • Grasp the battery plate cover and lift it off the the UPS.
  4. CyberPower UPS Battery Replacement: 4 단계, 이미지 3개 중 1개 CyberPower UPS Battery Replacement: 4 단계, 이미지 3개 중 2개 CyberPower UPS Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Pull out the battery to expose the terminal connectors.
    • Use needlenose pliers to disconnect both battery terminal connectors.
    • Do not pull the connectors by the wires, pull connectors by grabbing the connector itself.
    • With the battery terminal connectors disconnected, slide the battery all the way out.
  5. CyberPower UPS Battery Replacement: 5 단계, 이미지 3개 중 1개 CyberPower UPS Battery Replacement: 5 단계, 이미지 3개 중 2개 CyberPower UPS Battery Replacement: 5 단계, 이미지 3개 중 3개
    • The replacement battery should be a 12 volt, 9 amp-hour, sealed lead acid battery with f2 type connectors.
    • Install the new battery and reconnect the terminals.
  6. CyberPower UPS Battery Replacement: 6 단계, 이미지 3개 중 1개 CyberPower UPS Battery Replacement: 6 단계, 이미지 3개 중 2개 CyberPower UPS Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Insert the screw to secure the battery cover plate.
    • Tighten the screw with a Phillips #1 screwdriver.
  7. CyberPower UPS Battery Replacement: 7 단계, 이미지 3개 중 1개 CyberPower UPS Battery Replacement: 7 단계, 이미지 3개 중 2개 CyberPower UPS Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Plug system into the wall outlet.
    • Press the power button to turn on the unit.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jervon Stuart
회원 가입일: 10/07/20
217 평판
안내서 1개를 작성함
1가이드 댓글
This guide is very educative and helpful.
Philip Saviour - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 61
지난 30일: 272
전체 시간: 18,228
