주요 콘텐츠로 건너뛰기
CyberPowerPC Fangbook MS-1763 Battery Replacement
필요한 것
  1. CyberPowerPC Fangbook MS-1763 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Save all of your work and turn off the laptop before beginning.
    • Close the laptop and flip it so that the bottom side is facing up.
    • Locate the battery compartment.
  2. CyberPowerPC Fangbook MS-1763 Battery Replacement: 2 단계, 이미지 1/1
    • Pull the latches away from the battery compartment. The lid of the compartment should pop out of place.
  3. CyberPowerPC Fangbook MS-1763 Battery Replacement: 3 단계, 이미지 1/1
    • Tilt the lid so that it leans away from the laptop and exposes the battery below.
    • Remove the battery from the newly opened compartment.
결론
Insert a new battery and close the compartment lid to complete.
다른 한 분이 해당 안내서를 완성하였습니다.
Dorcas Oduntan
회원 가입일: 02/08/18
118 평판
안내서 1개 작성함
댓글 한 개
what is the battery name?
Jimmy Grant - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 1,062
