주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
CyberPowerPC RGB 7 Color Key Replacement Replacement
필요한 것
  1. CyberPowerPC RGB 7 Color Key Replacement Replacement, Plastic Casing: 1 단계, 이미지 2개 중 1개 CyberPowerPC RGB 7 Color Key Replacement Replacement, Plastic Casing: 1 단계, 이미지 2개 중 2개
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color Key Replacement Replacement: 2 단계, 이미지 2개 중 1개 CyberPowerPC RGB 7 Color Key Replacement Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color Key Replacement Replacement: 3 단계, 이미지 1개 중 1개
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color Key Replacement Replacement, LED Backlight: 4 단계, 이미지 1개 중 1개
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color Key Replacement Replacement: 5 단계, 이미지 1개 중 1개
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color Key Replacement Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully remove the LED board, which should now come free from the casing.
  7. CyberPowerPC RGB 7 Color Key Replacement Replacement, Key Replacement: 7 단계, 이미지 1개 중 1개
    • Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
  8. CyberPowerPC RGB 7 Color Key Replacement Replacement: 8 단계, 이미지 1개 중 1개
    • The keyboard should now be free to move, pick up the entire keyboard membrane and search for the key that needs to be replaced, to assist in remembering which key needs to be replaced place a small marker dot on the individual key back.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Katherine Von Braunsberg
회원 가입일: 02/12/18
377 평판
안내서 3개를 작성함
USF Tampa, Team S15-G2, Boczar Spring 2018 USF Tampa, Team S15-G2, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G2
4 회원들
안내서 10개를 작성함
1가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 138
전체 시간: 3,848
