주요 콘텐츠로 건너뛰기
CyberPowerPC RGB 7 Color Motherboard Replacement
필요한 것
  1. CyberPowerPC RGB 7 Color Motherboard Replacement, Plastic Casing: 1 단계, 이미지 1/2 CyberPowerPC RGB 7 Color Motherboard Replacement, Plastic Casing: 1 단계, 이미지 2/2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color Motherboard Replacement: 2 단계, 이미지 1/2 CyberPowerPC RGB 7 Color Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color Motherboard Replacement: 3 단계, 이미지 1/1
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color Motherboard Replacement, LED Backlight: 4 단계, 이미지 1/1
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color Motherboard Replacement: 5 단계, 이미지 1/1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color Motherboard Replacement: 6 단계, 이미지 1/1
    • Carefully remove the LED board, which should now come free from the casing.
  7. CyberPowerPC RGB 7 Color Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
  8. CyberPowerPC RGB 7 Color Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the motherboard and its attached cable from the plastic casing. The cord should now come free to replace.
결론
Katherine Von Braunsberg
회원 가입일: 02/12/18
359 평판
안내서 3개 작성하였습니다
USF Tampa, Team S15-G2, Boczar Spring 2018 USF Tampa, Team S15-G2, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 20
전체 시간: 407
