주요 콘텐츠로 건너뛰기
CyberPowerPC RGB 7 Color Plastic Casing Replacement
필요한 것
  1. CyberPowerPC RGB 7 Color Plastic Casing Replacement, Plastic Casing: 1 단계, 이미지 1/2 CyberPowerPC RGB 7 Color Plastic Casing Replacement, Plastic Casing: 1 단계, 이미지 2/2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color Plastic Casing Replacement: 2 단계, 이미지 1/2 CyberPowerPC RGB 7 Color Plastic Casing Replacement: 2 단계, 이미지 2/2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color Plastic Casing Replacement: 3 단계, 이미지 1/1
    • Lift up and remove the plastic casing.
결론
Braydon Lantz
회원 가입일: 02/12/18
229 평판
안내서 2개 작성하였습니다
USF Tampa, Team S15-G2, Boczar Spring 2018 USF Tampa, Team S15-G2, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 407
