주요 콘텐츠로 건너뛰기
Cyberpower Elite M1-131 Cord Replacement
필요한 것
  1. Cyberpower Elite M1-131 Cord Replacement, Cord: 1 단계, 이미지 1/3 Cyberpower Elite M1-131 Cord Replacement, Cord: 1 단계, 이미지 2/3 Cyberpower Elite M1-131 Cord Replacement, Cord: 1 단계, 이미지 3/3
    • Hold the mouse in a position where the feet are facing you.
    • With a plastic anti-static tweezer or a Spudger, take off the mouse feet carefully.
    • The feet will need to be reapplied during reassembly.
  2. Cyberpower Elite M1-131 Cord Replacement: 2 단계, 이미지 1/2 Cyberpower Elite M1-131 Cord Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws on the back.
    • Do not remove the white part on the mouse feet. They are sticky and will help put your mouse feet back on.
  3. Cyberpower Elite M1-131 Cord Replacement: 3 단계, 이미지 1/3 Cyberpower Elite M1-131 Cord Replacement: 3 단계, 이미지 2/3 Cyberpower Elite M1-131 Cord Replacement: 3 단계, 이미지 3/3
    • Gently put the mouse down with the sensor facing down and carefully pull the top shell from the mouse.
  4. Cyberpower Elite M1-131 Cord Replacement: 4 단계, 이미지 1/3 Cyberpower Elite M1-131 Cord Replacement: 4 단계, 이미지 2/3 Cyberpower Elite M1-131 Cord Replacement: 4 단계, 이미지 3/3
    • Grasp the 5-pin plastic white pin connector from both sides and gently pull it up.
    • Do NOT pull on the wires.
  5. Cyberpower Elite M1-131 Cord Replacement: 5 단계, 이미지 1/2 Cyberpower Elite M1-131 Cord Replacement: 5 단계, 이미지 2/2
    • Unwrap the old cable, pull it out, and remove it from sight.
  6. Cyberpower Elite M1-131 Cord Replacement: 6 단계, 이미지 1/3 Cyberpower Elite M1-131 Cord Replacement: 6 단계, 이미지 2/3 Cyberpower Elite M1-131 Cord Replacement: 6 단계, 이미지 3/3
    • With your new cable, place the 5-pin connector into the connector socket.
    • Do NOT push down on the wires.
    • Tuck in the cable.
    • Place the plastic cube in front of the mouse wheel. There will be a perfect fit for that cube to hold the cable in place.
  7. Cyberpower Elite M1-131 Cord Replacement: 7 단계, 이미지 1/2 Cyberpower Elite M1-131 Cord Replacement: 7 단계, 이미지 2/2
    • Place the top shell back on top of the mouse and press down until you hear a small click.
    • Lift the mouse so the sensor is facing you.
  8. Cyberpower Elite M1-131 Cord Replacement: 8 단계, 이미지 1/2 Cyberpower Elite M1-131 Cord Replacement: 8 단계, 이미지 2/2
    • Screw back in the four 2 mm screws that you removed earlier with your Phillips screwdriver.
  9. Cyberpower Elite M1-131 Cord Replacement: 9 단계, 이미지 1/2 Cyberpower Elite M1-131 Cord Replacement: 9 단계, 이미지 2/2
    • Reapply the mouse feet that you carefully took off earlier.
    • You can also apply new ones if you have any.
결론
Nathaniel A
회원 가입일: 09/19/23
169 평판
안내서 1개 작성함
Austin Community College, Team 1-1, Meigs Fall 2023 Austin Community College, Team 1-1, Meigs Fall 2023 회원
AUSTINCC-MEIGS-F23S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 37
전체 시간: 266
