주요 콘텐츠로 건너뛰기
CyberpowerPC Fangbook HX6 Screen Replacement
필요한 것
  1. CyberpowerPC Fangbook HX6 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • To replace the screen you will need a screwdriver (a size zero was used in this guide), and a tool that can be used to pry off the screen covering (a spudger was used in this guide).
  2. CyberpowerPC Fangbook HX6 Screen Replacement: 2 단계, 이미지 1/3 CyberpowerPC Fangbook HX6 Screen Replacement: 2 단계, 이미지 2/3 CyberpowerPC Fangbook HX6 Screen Replacement: 2 단계, 이미지 3/3
    • Insert the spudger gently into the seam that connects the front plate to the rest of the device.
    • Move the tool carefully around the screen and apply a small amount of pressure. You are trying to undo several clasps holding the front plate on.
    • Do this on all sides of the face plate except for the bottom. The bottom will have a strip of adhesive you will need to carefully pull off to separate the face plate from the bottom of the screen.
  3. CyberpowerPC Fangbook HX6 Screen Replacement: 3 단계, 이미지 1/2 CyberpowerPC Fangbook HX6 Screen Replacement: 3 단계, 이미지 2/2
    • Remove the two 4mm silver screws on both sides of the top of the screen.
    • Once you have removed them, gently pull the screen off of the aligning dials (the small plastic pieces to the left of the screws).
  4. CyberpowerPC Fangbook HX6 Screen Replacement: 4 단계, 이미지 1/2 CyberpowerPC Fangbook HX6 Screen Replacement: 4 단계, 이미지 2/2
    • At this point the only thing keeping the screen attached to the laptop is this small wire and connector shown here.
    • Gently pull the screen out and turn it over so that you can see where the connector is attached.
    • Carefully remove it. Once this is done you have successfully removed the screen from your laptop.
결론
Eric Box
회원 가입일: 09/12/18
159 평판
안내서 1개 작성함
University of Alabama, Team S1-G4, Bedsole Fall 2018 University of Alabama, Team S1-G4, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S1G4
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 814
