소개
Besoin d'accéder à l'intérieur de votre ASUS VG 248 ?
Voici un tutoriel vous expliquant comment retirer le cadre et ouvrir l'écran.
필요한 것
Les quatre vis sont masquées par des cache-vis en caoutchouc à l'arrière de l'écran.
Retirez les cache-vis avec un outil rigide et pointu, comme une spatule (spudger) en métal.
Pour réassembler l'appareil, veuillez suivre les instructions dans l'ordre inverse.
다른 19명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 8개
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
You could yes, but be very careful NOT to introduce dust into the panel!
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Guide to disassemble vg259qm
What power adapter and power cord is for gaming monitor Asus vg245qg? It was losted during moving.
https://www.youtube.com/watch?v=vV_Lbh2B...
Thanks, just watch this video.
I have the same issue as TJ Grainger. I have a very tiny spider, about 1 CM big spider (I can see by how it moves and it's legs projected from a white background) behind my screen. This is going to be annoying...
