주요 콘텐츠로 건너뛰기
D-Link HD Wi-Fi Camera Motherboard Replacement
필요한 것
  1. D-Link   HD Wi-Fi Camera Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link   HD Wi-Fi Camera Motherboard Replacement: 2 단계, 이미지 1/2 D-Link   HD Wi-Fi Camera Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link   HD Wi-Fi Camera Motherboard Replacement: 3 단계, 이미지 1/2 D-Link   HD Wi-Fi Camera Motherboard Replacement: 3 단계, 이미지 2/2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
결론
Morgen Jaques
회원 가입일: 09/28/17
533 평판
안내서 5개 작성하였습니다
Idaho State University, Team S4-G2, Watkins Fall 2017 Idaho State University, Team S4-G2, Watkins Fall 2017 회원
ISU-WATKINS-F17S4G2
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Where can I get the replacement motherboard? Been trying to search online, but to no avail.
Azlin Rahim - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 9
전체 시간: 849
