주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Computer Hardware 수리는 저희 서비스 설명서를 사용하십시오.
  1. D-Link 7-Port USB 2.0 HUB Teardown, Box: 1 단계, 이미지 1/2 D-Link 7-Port USB 2.0 HUB Teardown, Box: 1 단계, 이미지 2/2
    • D-Link 7-Port USB 2.0 HUB Model No.: DUB-H7 H/W Ver.: C1 UPC Code: 790069252389 Box
  2. D-Link 7-Port USB 2.0 HUB Teardown, Box contents: 2 단계, 이미지 1/2 D-Link 7-Port USB 2.0 HUB Teardown, Box contents: 2 단계, 이미지 2/2
    • Charger
    • USB cable
    • To open the USB HUB there are only 4 screws below the two pads.
Juan
회원 가입일: 11/03/14
138 평판
안내서 2개 작성하였습니다
댓글 5개
Anyone can tell what is the output voltage on this ? Mine shows 4.88V and I don't know if I should return it or not. My USB devices seem unstable.
adrianTNT - 답글
I returned this low performance hub. But the USB spec says that voltage should be 5.00±0.25 V. So, voltage may not be the issue. If the device works correctly when directly connected to the computer, then just return the USB HUB, and upload a video (on youtube or somewhere else) so people can see the problem and not buy this low performance USB HUB.
If you need a high performance USB HUB just get this:
http://plugable.com/products/usb2-hub-ag...
Juan -
These hubs have been better than the previous version, but only in that the two right hand ports are capable of fast charging. Almost all devices benefit from 2.1 amp fast charging now. As for reliability, they suck just as much as every other stupid USB sharing device.
Kelly - 답글
Thanks for this! But I'm confused: is this single TT or multi TT?
samulialapuranen - 답글
Can anyone tell me what a good DVD burner I can buy to burn copy write disk
tony brookshire - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 59
전체 시간: 6,465
