주요 콘텐츠로 건너뛰기
D-Link DCS-2630L Wi-Fi Camera Microphone Replacement
필요한 것
  1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Back casing: 1 단계, 이미지 1/1
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 2 단계, 이미지 1/1
    • Remove the back casing to expose the circuit board.
  3. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 3 단계, 이미지 1/1
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  4. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 4 단계, 이미지 1/1
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  5. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Microphone: 5 단계, 이미지 1/1
    • Remove the two 4.35 mm screws on the circuit board using the Philips head PH00 screw driver.
  6. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 6 단계, 이미지 1/2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 6 단계, 이미지 2/2
    • Detach the white plug by gently pulling on the black wires.
  7. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 7 단계, 이미지 1/2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 7 단계, 이미지 2/2
    • Remove the circuit board to expose the camera body.
    • At the same time, you will need to feed the wires through the circuit board and out the slot in the black plate under the circuit board.
  8. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 8 단계, 이미지 1/2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 8 단계, 이미지 2/2
    • Gently pull on the grey wire to detach the microphone from the camera body.
  9. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 9 단계, 이미지 1/3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 9 단계, 이미지 2/3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: 9 단계, 이미지 3/3
    • Detach the microphone from the circuit board by gently pulling on the grey wire.
결론
Stanley DeLuna-Dabrowski
회원 가입일: 03/21/18
133 평판
안내서 1개 작성함
IUPUI, Team S4-G2, Baechle Spring 2018 IUPUI, Team S4-G2, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S4G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 374
