주요 콘텐츠로 건너뛰기
D-Link DCS-2630L Wi-Fi Camera Speaker Replacement
필요한 것
  1. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement, Back casing: 1 단계, 이미지 1/1
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the back casing to expose the circuit board.
  3. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: 3 단계, 이미지 1/1
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  4. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: 4 단계, 이미지 1/1
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  5. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement, Speaker: 5 단계, 이미지 1/1
    • Remove the two 7.25 mm screws using the Ph00 head.
  6. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the back grey speaker plate
  7. D-Link DCS-2630L Wi-Fi Camera Speaker Replacement: 7 단계, 이미지 1/1
    • Remove the speaker by gently pulling on the wire near the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Collyn Dodge
회원 가입일: 03/21/18
323 평판
안내서 2개 작성하였습니다
IUPUI, Team S4-G2, Baechle Spring 2018 IUPUI, Team S4-G2, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S4G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 244
