주요 콘텐츠로 건너뛰기
D-Link DCS-5222L Lens Replacement
필요한 것
  1. D-Link DCS-5222L Lens Replacement, Lens: 1 단계, 이미지 1/3 D-Link DCS-5222L Lens Replacement, Lens: 1 단계, 이미지 2/3 D-Link DCS-5222L Lens Replacement, Lens: 1 단계, 이미지 3/3
    • Remove the four rubber feet with tweezers to access the screws.
    • Remove all four 7mm screws by using a #1 Phillips screwdriver.
    • Then, with your hands, pull off the lower part of the camera body.
  2. D-Link DCS-5222L Lens Replacement: 2 단계, 이미지 1/3 D-Link DCS-5222L Lens Replacement: 2 단계, 이미지 2/3 D-Link DCS-5222L Lens Replacement: 2 단계, 이미지 3/3
    • On the base motherboard, there are five connecting cables. Disconnect all of them from the motherboard gently using safety tweezers.
    • Do not cut or damage the cables.
    • Disconnecting the antenna cable from motherboard is not necessary.
  3. D-Link DCS-5222L Lens Replacement: 3 단계, 이미지 1/3 D-Link DCS-5222L Lens Replacement: 3 단계, 이미지 2/3 D-Link DCS-5222L Lens Replacement: 3 단계, 이미지 3/3
    • Remove the two 7mm screws holding the motor using a #1 Phillips screwdriver.
    • Pull off the motor and lift away the midbody of the camera using your hands.
  4. D-Link DCS-5222L Lens Replacement: 4 단계, 이미지 1/2 D-Link DCS-5222L Lens Replacement: 4 단계, 이미지 2/2
    • Separate the black camera shroud from the upper body by prying loose the tabs with a plastic opening tool or spudger.
    • Use your hands to wiggle the shroud free.
  5. D-Link DCS-5222L Lens Replacement: 5 단계, 이미지 1/3 D-Link DCS-5222L Lens Replacement: 5 단계, 이미지 2/3 D-Link DCS-5222L Lens Replacement: 5 단계, 이미지 3/3
    • Use a #1 Phillips screwdriver to unscrew the four 5mm screws on both sides of the black camera housing to separate it from white body.
    • Unscrew the two 7mm #1 Phillips screws on both sides of the camera housing to open it.
  6. D-Link DCS-5222L Lens Replacement: 6 단계, 이미지 1/3 D-Link DCS-5222L Lens Replacement: 6 단계, 이미지 2/3 D-Link DCS-5222L Lens Replacement: 6 단계, 이미지 3/3
    • Gently disconnect the three cables from the small motherboard using safety tweezers.
    • Use a #0 Phillips screwdriver to remove the two black 2mm screws and a #1 Phillips screwdriver to remove the 2 silver 6mm screws.
    • Separate the board from the black housing.
  7. D-Link DCS-5222L Lens Replacement: 7 단계, 이미지 1/3 D-Link DCS-5222L Lens Replacement: 7 단계, 이미지 2/3 D-Link DCS-5222L Lens Replacement: 7 단계, 이미지 3/3
    • Using your fingers, remove the focus adjustment ring.
    • Twist the lens to unscrew it from the camera module.
    • Replace the broken lens with new one and reassemble all parts of the camera respectively.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Atefeh Rahmani
회원 가입일: 10/27/18
172 평판
안내서 1개 작성함
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 13
전체 시간: 933
