주요 콘텐츠로 건너뛰기
D-Link DCS-5222L Motherboard Replacement
필요한 것
  1. D-Link DCS-5222L Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 D-Link DCS-5222L Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove the four rubber feet on the bottom of the camera using your fingers or a pair of tweezers.
  2. D-Link DCS-5222L Motherboard Replacement: 2 단계, 이미지 1/1
    • Using a #1 Phillips screwdriver, remove the four 7mm screws that are exposed by the removed feet.
  3. D-Link DCS-5222L Motherboard Replacement: 3 단계, 이미지 1/2 D-Link DCS-5222L Motherboard Replacement: 3 단계, 이미지 2/2
    • Using your hands, open the camera body by wiggling the bottom free from the upper shell.
    • Open the shell carefully, as the motherboard is attached to the bottom of the body; all of the components in the upper body are accordingly connected to the bottom. Likewise, the WiFi antenna is mounted to the upper shell, but a wire connects it to the motherboard on the bottom of the body.
  4. D-Link DCS-5222L Motherboard Replacement: 4 단계, 이미지 1/3 D-Link DCS-5222L Motherboard Replacement: 4 단계, 이미지 2/3 D-Link DCS-5222L Motherboard Replacement: 4 단계, 이미지 3/3
    • Disconnect the five quick connections attaching the various cables to the motherboard with your fingers or blunt ended tweezers.
  5. D-Link DCS-5222L Motherboard Replacement: 5 단계, 이미지 1/2 D-Link DCS-5222L Motherboard Replacement: 5 단계, 이미지 2/2
    • Using your soldering iron, heat the antenna contacts on the motherboard until the wire releases.
    • Soldering Irons are hot and can burn you and ignite flammable materials.
  6. D-Link DCS-5222L Motherboard Replacement: 6 단계, 이미지 1/1
    • Using a #1 Phillips screwdriver, remove the single 7mm screw holding the motherboard in place.
  7. D-Link DCS-5222L Motherboard Replacement: 7 단계, 이미지 1/3 D-Link DCS-5222L Motherboard Replacement: 7 단계, 이미지 2/3 D-Link DCS-5222L Motherboard Replacement: 7 단계, 이미지 3/3
    • Wiggle free the motherboard from the bottom of the body.
    • There are two pegs that limit the motherboard's rotation. Have some patience when wiggling it free.
    • The power and ethernet ports have ledges along their top surface. These must be removed from the body at an angle relative to the horizontal.
결론
Ryan Null
회원 가입일: 10/26/18
377 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 19
전체 시간: 1,047
