주요 콘텐츠로 건너뛰기
D-Link DCS-5222L Motor Replacement
필요한 것
  1. D-Link DCS-5222L Motor Replacement, Motors: 1 단계, 이미지 1/3 D-Link DCS-5222L Motor Replacement, Motors: 1 단계, 이미지 2/3 D-Link DCS-5222L Motor Replacement, Motors: 1 단계, 이미지 3/3
    • Remove the four rubber feet on the bottom of the camera with tweezers.
    • Remove the four screws using a Phillips #1 screwdriver.
    • Remove the lower piece of the camera body.
  2. D-Link DCS-5222L Motor Replacement: 2 단계, 이미지 1/2 D-Link DCS-5222L Motor Replacement: 2 단계, 이미지 2/2
    • Remove the motherboard and bottom of the camera body.
    • Disconnect the five cables from the motherboard using tweezers.
  3. D-Link DCS-5222L Motor Replacement: 3 단계, 이미지 1/2 D-Link DCS-5222L Motor Replacement: 3 단계, 이미지 2/2
    • Use a #1 Phillips screwdriver to remove the two 7mm screws holding the motor in place.
  4. D-Link DCS-5222L Motor Replacement: 4 단계, 이미지 1/2 D-Link DCS-5222L Motor Replacement: 4 단계, 이미지 2/2
    • Using your hands, separate the bottom of the body from the upper portion.
  5. D-Link DCS-5222L Motor Replacement: 5 단계, 이미지 1/2 D-Link DCS-5222L Motor Replacement: 5 단계, 이미지 2/2
    • To remove the top of the camera you must push in the black tabs using the spudger. There are 3 tabs per side.
    • While pushing in the tabs, you can now lift the top black portion of the camera using your hands.
  6. D-Link DCS-5222L Motor Replacement: 6 단계, 이미지 1/2 D-Link DCS-5222L Motor Replacement: 6 단계, 이미지 2/2
    • With a little wiggle, the camera module will come free from the body.
    • Unscrew the two 7mm screws on the camera using a #1 Phillips screwdriver.
  7. D-Link DCS-5222L Motor Replacement: 7 단계, 이미지 1/2 D-Link DCS-5222L Motor Replacement: 7 단계, 이미지 2/2
    • Pry apart the camera housing with your fingers to reveal the second motor.
  8. D-Link DCS-5222L Motor Replacement: 8 단계, 이미지 1/1
    • Unscrew the two 6mm screws holding the motor in place with a #1 Phillips screwdriver.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jason Munyon
회원 가입일: 10/30/18
268 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 2개
Where can I buy new motor?
Michael Williams - 답글
I do not know, I purchased a “for Parts” camera on e-bay for $15.00 and used the motor from that unit.
Ed Wheelbarger - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 16
전체 시간: 706
