소개
If your camera is failing to move in a certain direction one of the two motors inside may be malfunctioning. If this is the case the motor will need to be replaced. The replacement process is pretty simple and doesn't need many tools. It is important to keep track of the small screws, they are easily lost.
필요한 것
Remove the four rubber feet on the bottom of the camera with tweezers.
Remove the four screws using a Phillips #1 screwdriver.
Remove the lower piece of the camera body.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Where can I buy new motor?
I do not know, I purchased a “for Parts” camera on e-bay for $15.00 and used the motor from that unit.
