주요 콘텐츠로 건너뛰기
D-Link DCS-5222L Speaker Replacement
필요한 것
  1. D-Link DCS-5222L Speaker Replacement, Speaker: 1 단계, 이미지 1/3 D-Link DCS-5222L Speaker Replacement, Speaker: 1 단계, 이미지 2/3 D-Link DCS-5222L Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Remove the four rubber pieces to gain access to the screws.
    • Remove the four 7mm screws with a #1 Phillips screwdriver.
    • Remove the bottom of the camera body.
  2. D-Link DCS-5222L Speaker Replacement: 2 단계, 이미지 1/2 D-Link DCS-5222L Speaker Replacement: 2 단계, 이미지 2/2
    • Using safety tweezers, disconnect the 2-wire connector with the red and black leads located close to the ethernet and SD ports.
    • Disconnect the cables gently.
  3. D-Link DCS-5222L Speaker Replacement: 3 단계, 이미지 1/2 D-Link DCS-5222L Speaker Replacement: 3 단계, 이미지 2/2
    • The speaker is circular, black and silver in color with a red and black cord. It is easily removed from the upper body of the camera with your fingers or safety tweezers.
결론
Jason Munyon
회원 가입일: 10/30/18
268 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 9
전체 시간: 302
